Is it normal for me to not be able to close my 3.3 carb all the way before the screw comes out? Because it will only close about 1mm then the screw is loose.
Sounds like a linkage issue. Disconnect the linkage, see if the carb will then close all the way without the screw falling out. If it does you will need to adjust the linkage.
