2nd gear
nlcmobsta183
reading
i have a exceed rc 1/10 ultra its been running good but it just stop switching to 2nd gear i try to lean out the engine but I'm having no luck getting it to switch to second anybody have any ideas how to fix it?
if it can be adjusted there should be a littl rubber port hole on the center diff if you pull the cap off and spinn the gears real slow, you will see a small allen screw in there. if you turn it counter clockwise it will shift sooner. it is the same on all my nitro's. but i am not familuer with your model. check it and let me know what you find
sweet deal. it will take a couple of try's till you find the setting you like.. i like the motor to wind out as high as possible so you get a full range of rpm's from the motor
