Greywolf74
I'M TO BLAME!
Lifetime Supporter!
RC Showcase: 8
@WoodiE The biggest PC project I'm working on right now is a new Gaming rig. I'm building my dream PC and I'm sparing little expense. I lost exact count but I believe I'm in for around $5100 +/- $300ish. Heres so info and pics
I'm mostly working on making and sleeving all of the cables myself so I havent made much progress on putting it together. making my own cabling, adding custom switches, and watercooling with hard acrylic water tubing are all new to me so the learning curve is huge on this build. Plus I complicated matters by duplicating and even triplicating some of the watercooling components so it may be months before I'm done with it especially since i dont get tons of time to work on it between work, my wife, and LoL. This Rig will be mostly White and UV reactive Red with UV lighting. I still have not ordered the watercooling fittings. I'll post more pics as I get them.
this is actually a 660Ti not a 670. It was mislabeled by the manufacturer.
This is my second GTX 660Ti. I'm running them in SLI. Two GTX 660Ti in SLI benchmark about the same as a GTX Titan without the $1000 price tag.
Asus Maximus VI Forumla Motherboard. about as top of the line as it gets in motherboards.
Corsair AX860 Watt Platinum rated PSU. Was going to go with the AX1200 Watt but got such a good deal on the 860 I figured Id get it since most PSUs like to run with a fairly heavy load on them anyway.
Watercooling block for one of my video cards….for somereason I forgot to take a pic of teh other one but its virtually the same anyway.
Both of the back plates for my video cards
My UV reactive red sata data cables
UV LED strip. (Also have 2 UV CCFL tubes too but no pics)
14 x 120mm Corsair Static Pressure fans for cooling the radiators.
Corsair 140mm high airflow rear exhaust fan
Music activation box for the lighting.
combination front loading DVD burner and solid state drive mount.
Two 3TB Toshiba 7200RPM hard drives for storage
16GB of Corsair Dominator Platinum 1866Mhz RAM w/ LED light bars
