200 mm bodies
chevelleman
Q1 Does anyone out there know a place that I can purchase a body for my TC3. Particularly a 1967 Chevelle body. I am new to the sport and really becoming ate up quickly.
Q2 The engine that i have is a .12 and it blows the tires off with the carb restrictor removed and ideas out there about good tires that will grip better than the rubber ones provided? I have found several site advertising foam tires of various compounds.
:n00bie:
:buggy1:
To answer your second question, I use HPI's X-pattern radials. Has a soft compound and gives pretty good grip for the asphalt basher. I know what you mean about the rubber that comes with the NTC3. I balded mine out in no time.
I am still using it on my NTC3, but when the tires were new, I originally had an OS .12CR-Rx. Now it's a .15CV-rx and I don't expect these tires to last very long. This tire comes in both a regular radial and a belted radial. The belted radial will keep more of the tread on the ground when cornering. (so they say)
1. Dont know where you can find the Chevelle body for ANYTHING, but HPI, OFNA and Parma all make a wide selection. Just no chevelle.
2. Are you running indoor carpet or outdoor pavement?
