Hi,
I currently purchased a 1100mah Ni-Mh receiver pack battery made by APS and I am using a Pirahna Digital Peak Charger.
I have the charger set up with the following configuration:
Battery Type - NiMH
Capacity - 1100mah
Set Rate - Auto or 1.1
Peak - 8mv/c
However, when I charge my battery, it stops usually within 30 minutes and the charge in the battery as per the charger is in the 200 - 300 range. I have also noticed that I only get about 30 minutes of run time. I have two batteries which I brought new.
Can anyone advise me on what changes I should make to the above configuration that will give me a better charge?
Thanks,
Brian
Battery Type - NiMH
Capacity - 1100mah
Peak - 8mv/c
Thanks,
Brian
