I am brand new to NITRO RC, (not that I am "Experienced" with Elec.)d
I recently purchased a Savage X from a good friend of mine, it had one gallon of fuel ran through it. My friend had it running quite rich, to ensure longevity.
I have LOTS of neighbors near by and decided to try the exhaust silencer, it seems to work better than I thought it would.
So I started to tune the Truck, like the manual says - 1st tank nothing really changed with my tuning. 2nd Tank - Got it running pretty nice. Just needs a little FINE tuning now. By the end of the Second tank of fuel I had worn out the Slipper Clutch pad. I am tuning for more power BTW.
I thought no biggy, I know they are cheap and meant to wear and save other parts.
I put a new one in. next tank of fuel I toasted it sooner.
So I open up the manual and see that the truck should have 2 clutch pads. Mine only has 1 (RTR Model differance?)
So I order the part to hold the second Clutch disc in. I got it today and installed 2 Clutch pads (I would think this should give it ATLEAST 70% more holding power).
Well I installed it, and went to put the on nut that holds the "tension spring?" and its on, but the shaft if not long enough. I set it up, and I bet it will work, but I also bet it will vibrate loose, as I do not think the Nylon is touching to help keep it on.
IS there a different shaft I have to buy? Does anyone know the part number or name?
Also does someone know the part numbers for the spring and nut? I may end up loosing them this afternoon when trying the truck
