1/18 comp built
Martin trj
SoCal
  2. Crawling
Hey guys, been busy with a lot but all is good. I started to slowly build an Apollo rig, I’m waiting for Meus racing axles and I gotta set of nexxracing shocks but looks like the front driveshaft has to be custom, what are you comp builders using? I’m using a
High trail in the back.
Also, should I flip the motor around?
Looks like you might have to for front driveshaft clearance.
That motor and trans looks sweet!
Got it, thanks. I’ll flip it today later. It’s the unity. We’ll see how it works on that rig.
I just moved into a new place and right behind it, it has this mini trail I can definitely place a course with some rocks. Can’t wait to test it out.
Well, it’s done. I ran it but seems like the driveshaft hits the links and I’m not sure why the servo is very laggy. Also, not sure how to attach the body to it. Still, fun stuff.
Ok, I’m pretty much done. I am having issues with, either the injora driveshafts or the shaft connecting them. I the replacement tomorrow. I’d like to hear your opinion, this is how the driveshafts look installed.
Also might want to flip the drive shaft around, you want the splined section on the bottom, and the housing section up top. This will allow any water and debris to clear out easier. If it is the way you have it, the water and debris will get stuck inside, and eventually seize it up so it don't slide. Make sense?
