Axial AX10 Scorpion Heavy Duty Gear Set
Axial AX10 Scropion Heavy Duty Gear Set
Axial has found another way to improve the ever popular Axial AX10 Scorpion, this time with their new Axial AX10 heavy duty gear set. The new Axial AX10 heavy duty gear set offers additional strength due to the gears being made from hardened steel, which also increases the trucks weight adding to it's low center of gravity. With the new Axial AX10 Scorpion heavy duty gear set, Axial has also improve the gear mess reducing the slop that may be found in the drive train!
Axial AX-10 Heavy Duty Gear Set Features
  • Improved gear mesh reduces drive train slop
  • Hardened steel for increased strength and additional weight in the axle
  • One set per axle required
Part #: AX30395 – Axial AX-10 Heavy Duty Bevel Gear, 38T
MSRP: $ 30.00
Join the discussion about the new Axial AX10 Scorpion heavy duty gear set in our RC Rock Crawlers forum!
