HPI Savage Octane Manual and Parts Listing and Tips
Status
Not open for further replies.
WoodiE
Kind of good admin
Administrator
Lexington, KY
HPI Savage Octane XL Manuals
Savage Octane Parts Listing
Chassis Components
#105891 - Upper Arm Brace 4x54x3mm
#105892 - Bulkhead Lower Plate 2.5mm
#105893 - Lower Arm Brace 4x54x3mm
#108934 - Roll Bar Set
#108938 - Radio Box Set
#108940 - TVP Chassis (Right/Gray/3mm)
#108942 - TVP Chassis (Left/Gray/3mm)
#108944 - Fuel Tank Set
#108946 - Steering Servo Mount Set
#108956 - Engine Plate (Gray/4mm)
#109786 - Roll Bar Parts/Tank Mount Set
#111295 - Joint 19x54x20mm
#111297 - Steering/Throttle Rod Set
#85059 - Bumper Set/Long Body Mount Set
#85234 - Skid Plate/Body Mount/Shock
#85235 - Gear Box/Bulkhead Set
#86803 - Joint Post 4x6x74mm (2pcs)
Drivetrain
#105551 - Sintered Bulletproof Diff
#107456 - Slipper Pad 16x33x1.0mm (Tsc)
#109040 - Drive Gear 24t (3 Speed)
#109044 - Drive Gear 30t (3 Speed)
#109046 - Idler Gear 38t (3 Speed)
#109052 - Idler Gear 32t (3 Speed)
#109268 - Brake Hub 6x8x19mm
#109448 - Center Gear Box Set
#109907 - Drive Shaft 8x70.5mm
#111094 - Third Gear Clutch Holder
#111097 - Second Gear Clutch Holder
#111167 - Idler Gear 31tx1m (Steel)
#111169 - Drive Gear 30tx1m (Steel)
#111800 - Heavy Duty Spur Gear 47tx5mm
#111802 - Drive Shaft 6x73mm
#113002 - Spacer 8x12x14mm
#72130 - Stainless Steel Slipper Plate
#72367 - Brake Spring 4x5x20mm (2pcs)
#77054 - Spur Gear 44 Tooth (Savage 3
#77058 - Pinion Gear 18 Tooth (Savage 3
#86054 - Dogbone 8x142mm (Black)
#86081 - Gear Shaft 6x12x78mm (Black)
#86082 - Cup Joint 6x13x20mm
#86083 - Cup Joint 8x19mm (Black/2pcs)
#86094 - Screw Shaft M4x2.5x12mm
#86095 - Screw Shaft M5x3x18mm
#86099 - Diff Case Washer 0.7mm (6pcs)
#86130 - Slipper Clutch Hub
#86246 - Super Heavy Duty Drive Shaft
#86248 - Super Heavy Duty Diff Shaft
#86249 - Super Heavy Duty Wide Axle
#86362 - Clutch Gear Hub (Savage 3
#86804 - Hex Wheel Hub 17mm
#86827 - Alloy Diff Case
#87042 - Spring 4.9x8x7mm/Washer 4
#87193 - 4 Bevel Gear Differential
Suspension & Steering
#100948 - Shock Body Set (113-157mm)
#100949 - Shock Parts Set
#100950 - Shock Shaft 3.5x90mm (4pcs)
#100961 - Shock Cap Set
#102365 - Big Bore Sport Shock Set
#102522 - Heavy Duty Servo Saver Spring
#105894 - Steering Post 12x47mm
#15415 - O-Ring (50x2.6mm/Black/4pcs)
#6561 - Spring 18x20x1.7x5 (Black/2pcs)
#6811 - O-Ring 6x9.5x2mm (Black/8pcs)
#75075 - Silicone O-Ring S4 (3.5x2mm/12pcs)
#75080 - O-Ring 7x11x2.0mm (Black/8pcs)
#85048 - Upright Set
#85058 - Steering Crank/Servo Saver Set
#85231 - Shock Spacer Parts Set
#85238 - Suspension Arm Set
#86059 - Ball 6.8x7.3x3mm (Black/4pcs)
#86071 - Flange Shaft 4x62mm
#86073 - Shaft 4x78mm (Silver/2pcs)
#86074 - Shaft 4x46mm (Silver/2pcs)
#86090 - Steering Crank Post 6x49mm
#86551 - Shock Spring 18x80x1.8mm 14
#86555 - Shock Spring 18x80x1.8mm 10
#87058 - Rubber Tube 3x8x10mm
#87500 - Bladder 16x5mm (Flat Type)
#87524 - Rubber Bump Stop (4pcs)
#93535 - Turnbuckle M4x70mm (4pcs)
Engine & Engine Parts
#108948 - Throttle Servo Saver Set
#108960 - Clutch Bell 14tx33x20mm
#109054 - Air Filter Set
#109061 - Inner/Outer Foam Element Set
#109258 - Carburetor (Wt-668) (Octane 15cc)
#109762 - Gasket 11x28x42x0.5mm
#109784 - Exhaust Spring 0.9x5x13mm
#109866 - Fly Wheel 9.6x43x16mm (Quadra)
#109904 - Engine Mount Set 25x30x78mm
#111335 - Woodruff Key 2.5mm
#111337 - Thermal Insulator
#111338 - Ignition System
#111339 - Spark Plug 14mm (Cm-6)
#111340 - Heatsink Head (Octane 15cc)
#111341 - Cylinder Liner/Piston Set
#111342 - Connecting Rod (Octane 15cc)
#111343 - Crankshaft (Octane 15cc)
#111345 - Recoil Starter
#111346 - Timing Sensor
#111350 - Aluminum Quadra Clutch
#111351 - Air Filter Joint Set
#111390 - Octane 15cc Engine
#111392 - Head Gasket 0.2mm (28x34mm)
#111790 - Cooling Fan Unit Set
#112387 - Crankcase (Octane 15cc)
#112388 - O-Ring (35x39mm)
#112389 - Crankcase Plug (10x12x7.6mm)
#112488 - Manifold 21xm4x90mm
#112494 - Muffler 19x56x180x11mm
#112654 - Muffler Mount / Hanger Wire
#112655 - Intake Air Reducer Set
#113241 - Idle Adjust Washer Set
#15465 - Air Filter Gasket (2pcs)
#86710 - Silicone Exhaust Coupling
#87469 - Fuel Tank Cap
Electronics
#104058 - HPI TF-20e 2.4ghz Transmitter
#104060 - HPI RF-30 Receiver 2.4GHz /2ch/6V 5cell Battery)
#104105 - HPI SF-10w Servo(Waterproof/4.5kg-cm6.0V)
#105366 - HPI SF-50wp Servo(Waterproof/12.0kg-cm6.0V)
#110208 - Servo Extension Wire 190mm
#110721 - Receiver/Ignition Switch
#Z150 - Antenna Pipe Set
Batteries & Chargers
#111834 - Ac Multi-Plug Charger With
Hardware
#109473 - Step Screw M3x4x22mm (2pcs)
#110211 - Binder Head Screw M3x25mm
#111298 - Tp. Flanged Screw M3x15mm
#111336 - Button Head Screw 4-40x8mm
#112933 - Cap Head Screw M5x50mm (2pcs)
#6122 - Body Pin
#6123 - Body Pin
#6163 - Servo Tape 20x100mm (10pcs)
#72111 - Shim Set 3x5mm (M3x5x0.1-0.2-0
#86972 - Washer 6x15x0.2mm (6pcs)
#87511 - Servo Grommet (8pcs)
#94505 - Cap Head Screw M4x12mm (10pcs)
#94506 - Cap Head Screw M4x15mm (10pcs)
#94520 - Cap Head Screw M4x50mm (6pcs)
#B021 - Ball Bearing 5x10x4mm (2pcs)
#B023 - Ball Bearing 6x13x5mm (2pcs)
#B026 - Ball Bearing 6x12x4mm (2pcs)
#B032 - Ball Bearing 10x16x5mm (2pcs)
#B085 - Ball Bearing 8x16x5mm (2pcs)
#Z224 - Washer 3x8mm (10pcs)
#Z240 - C Clip 8mm (4pcs)
#Z243 - E Clip E3mm (10pcs)
#Z245 - E Clip E5mm (10pcs)
#Z260 - Pin 2.5x12mm (12pcs)
#Z282 - Step Screw M3x14mm (4pcs)
#Z286 - Step Screw M3x20mm (6pcs)
#Z288 - Step Screw M4x20mm (4pcs)
#Z303 - Cap Head Screw M3x42mm (6pcs)
#Z421 - Cap Head Screw M2.6x8mm (12pcs)
#Z488 - Tp. Flanged Screw M2.6x12mm
#Z515 - Binder Head Screw M3x5mm (6pcs)
#Z516 - Binder Head Screw M3x10mm
#Z518 - Binder Head Screw M3x12mm
#Z519 - Binder Head Screw M3x15mm
#Z520 - Binder Head Screw M3x18mm
#Z525 - Flat Head Screw M3x6mm (10pcs)
#Z527 - Flat Head Screw M3x10mm (6pcs)
#Z529 - Flat Head Screw M3x15mm (6pcs)
#Z530 - Flat Head Screw M3x18mm (6pcs)
#Z541 - Cap Head Screw M3x6mm (6pcs)
#Z542 - Cap Head Screw M3x8mm (12pcs)
#Z543 - Cap Head Screw M3x10mm (6pcs)
#Z545 - Cap Head Screw M3x15mm (6pcs)
#Z547 - Cap Head Screw M3x20mm (6pcs)
#Z567 - Tp. Binder Head Screw M3x10mm
#Z568 - Tp. Binder Head Screw M3x12mm
#Z569 - Tp. Binder Head Screw M3x15mm
#Z570 - Tp. Binder Head Screw M3x18mm
#Z581 - Tp. Flat Head Screw M3x18mm
#Z613 - Binder Head Screw M4x10mm
#Z623 - Flat Head Screw M4x12mm (6pcs)
#Z632 - Tp. Binder Head Screw M4x10mm
#Z634 - Tp. Binder Head Screw M4x15mm
#Z644 - Tp. Flat Head Screw M4x15mm
#Z649 - Tp. Flat Head Screw M4x30mm
#Z661 - Lock Nut M2.6 (4pcs)
#Z663 - Lock Nut M3 (6pcs)
#Z680 - Flanged Lock Nut M5x8mm
#Z684 - Flanged Lock Nut M4 (4pcs)
#Z685 - Washer 2.7x6.7x0.5mm (10pcs)
#Z694 - Washer M5x10x0.5mm (10pcs)
#Z700 - Set Screw M3x3mm (6pcs)
#Z721 - Set Screw M4x4mm (4pcs)
#Z852 - Washer 5x7x0.2mm (10pcs)
#Z877 - Washer 8x10x0.2mm (10pcs)
#Z892 - Washer 10x12x0.2mm (10pcs)
Bodyshells & Body Accessories
#112828 - Gtxl-1 Painted Body (Black)
Wheels & Tires
#3188 - Mag-8 Wheel Matte Chrome
#4465 - Terra Pin Tires S-Compound
Fuel & Fuel Accessories
#87467 - Fuel Line (Black/50cm)
#87468 - Fuel Line (Yellow/50cm)
Tools
#110562 - Spark Plug Wrench (14mm)
Savage Octane Tips and Mods
Savage Octane Videos
Breaking in your Savage Octane:
If your Savage Octane XL won't start:
Tuning your Savage Octane engine:
Tuning the Savage Octane 3-speed transmission:
Status
