XRAY has just released their new 1/8th scale buggy, the XRAY 808E. The XRAY 808E is based off the very successful XRAY 808 nitro buggy. The new XRAY 808E has been designed for professional racers, the 808E features ultra-high performance parts, finest quality materials, unmatched precision in manufacturing, and backed up with legendary XRAY support and service.
The XRAY 808E is a professional race car delivered in a kit version to allow you to choose your own electronics. Supported by XRAY dedication, passion, and heritage of performance, the XRAY 808E is ready to take you to the winning circle.
XRAY 808E Specs
- premium high-competition off-road electric-powered buggy
- kit version only – for professional racers
- based on the ultra-successful 808 platform, sharing a majority of parts
- efficient Zero Kingpin suspension
- strong, lightweight molded steering blocks with molded-in steel bushings
- well-proven 808 suspension parts and geometry
- ultra-low CG, all parts centralized in chassis
- optimized front/rear and left/right weight balance for perfect jumping
- pure racing design, highest-performance ultra-durable parts
- ultra-lightweight high-tensile transmission parts hand-made from special world-renowned top-secret self-developed HUDY Spring Steel
- drivetrain includes 22 high-speed rubber-sealed bearings for maximum efficiency, speed, and durability
- ultra-precision front/rear and center diffs with HUDY Spring Steel outdrives
- pinions, spurs, crown gears and clutchbell manufactured by HUDY
- optimized multiple upper/lower shock mounting locations for front and rear
- exclusive adjustable turnbuckles made from Swiss 7075 T6 aluminum
- flexible suspension holders with integrated preset optimal suspension geometry
- high-tensile Swiss 7075 T6 hard-anodized chassis
- ultra-strong inboard & outboard suspension pivot pins
- direct Shaft Connection to the pinion gear
- front & rear anti-roll bars
- narrow servo saver and steering system
- front & rear flexible composite brace
- gearboxes with Labyrinth Dust Covers™
- premium-grade graphite shock towers: 4mm extra-thick front & 3.5mm thick rear
- big-bore oversized shocks for excellent handling on bumpy tracks and big jumps
- threaded big-bore hard-anodized shock bodies
- protective folding rubber shock boots for big-bore shocks, front & rear
- ultra-low XRAY racing body
- XRAY Premium Shock Oils for perfect consistency
Discuss the XRAY 808E buggy in our 1/8th scale buggy forum.
