Reedy is now shipping their Wolfpack battery packs equipped with Deans Ultra Plug connectors in 7-cell flat 8.4V versions!
Reedy Wolfpacks are assembled using Reedy’s high-tech NiMH sub-C SC-R cells. This exclusive cell features high capacity for extended run times while delivering maximum output thanks to its current carrying capabilities and ultra-low internal resistance. To improve power output, prevent meltdowns, and increase reliability, an industry-standard Deans Ultra Plug connector has been fitted.
To further minimize power-robbing resistance and heat, welded connections between each cell and thick 14AWG silicone power wires ensure maximum performance and reliability. Also available is an adapter that allows you to charge your Deans Ultra Plug connector-equipped Wolfpack.
Part numbers:
#609 TAM to DEANS Charge Adapter – $6.99
#724 WolfPack 8.4V 3000mAh with DEANS – $62.99
#725 WolfPack 8.4V 3600mAh with DEANS – $74.99
