Team Losi XXX-CR
Team Losi celebrates their 25th year of offering racers unmatched race proven designs and features with the release of the Team Losi XXX-CR 2WD off-road racing buggy. The CR designation is a throw back to the Losi heritage offering “Competition Ready” kits incorporating innovative thinking, cutting edge design and unmatched material technology. The Team Losi engineering and development team have redesigned and revised a number of key elements for the XXX-CR to take full advantage of the latest generation of hi-performance motors, batteries, and tires.
The Team Losi XXX-CR also benefits from Team Losi’s exclusive new “EA3” composite material for more durability than any buggy you’ve ever driven. The unique combination of design, hi-tech components and materials lets the Team Losi XXX-CR produce incredible acceleration and stability through the roughest track sections and tightest turns. The wide range of adjustability and predictable handling makes the Team Losi XXX-CR even easier to drive fast.
Team Losi XXX-CR Competition 2WD Buggy Kit Features:
- Critical components molded from Team Losi’s exclusive EA3 class composites
- Team Losi XXX Transmission with long-life ball differential, Kevlar spur gear, dual disk slipper and durable molded gear cover
- Revised rear suspension geometry for increased traction and stability
- Variable Length Arms for increased adjustability and tuning
- Team Losi rebuildable dogbones
- Revised rack steering configuration with ball bearings for smooth response
- Redesigned front shock tower with additional mounting positions and optimized suspension travel
- New Heavy Duty “HD” high-strength ball studs
- New battery strap for increased strength and rigidity
- Genuine Team Losi soft compound racing tires
- Titanium nitride hinge pins and shock shafts
- Machined titanium turnbuckles
- Hard anodized suspension balls for durability and decreased friction
- Threaded shock bodies with aluminum adjustment collars for easy suspension tuning
- Tunable multi-element wing package
Part #: LOSA0032
Discuss Team Losi’s new 2WD buggy in our General Electric Talk forum.
