RC Lights just released another nice LED controller, the 6 LED microBRAKE controller. Directly power up to 6 LEDs. Current limiting resistors are built right in.
Using the microBRAKE 6 LED Controller, LEDs can be directly powered from the throttle channel of the RX using the included RX Pass-Thru mini Y-harness also dual intensity brake light action is built right in! Plus throttle channel input fully reversible.
RC Lights designed the 6 LED microBRAKE controller so that the LEDs are split into two banks: 4 constant; and 2 switched dim or full bright depending on throttle stick position (gas or brake).
Throttle center-stick auto-detect for precise lighting effects every time. All link channels have been eliminated to make a nice, compact little controller capable of the most common of needs for car and truck R/C bodies.
Bundled with these complete systems: #5006 and #106-MB
#5006: Is a universal LED system that can be installed in any 1:12 to 1:8 size Radio Control Car or Truck with accessible throttle servo or ESC plug. Everything needed for a complete installation is included with every system.
#106-MB: Is a LED system designed for use with RPM Light Canisters. This system will light the 4 LED front bumper or 4 LED narrow roof bar AND provide dual intensity brake light action for the 2 LED tail lights. Everything needed for a complete installation is included with every system.
Part #: RCL5052 – RC Lights 6 LED microBRAKE controller
