Pro Boat Sonicwake RTR Self-Righting Deep-V Boat
Pro Boat Sonicwake boat
sonicwake deep-v boat
With features such as the self-righting design that will flip the boat upright automatically and the ability to reach 50+ MPH, the new Pro Boat Sonicwake 36″ deep-v boat has been designed with both beginners and avid boaters in mind.
The Pro Boat Sonicwake 36″ boat features a 4 pole 1900Kv brushless motor that is water cooled. Along with a waterproof, high torque steering servo and a Spektrum STX2 2.4 GHz FHSS radio.
pro boat sonicwake deep-v boat top
Pro Boat Sonicwake specs
  • Beam: 11 inches (279.4 mm)
  • Boat Type: Deep-V
  • Completion Level: Ready-To-Run
  • Drive System: Flex Shaft
  • Hull Height: 4 in (101.6 mm)
  • Hull Material: ABS
  • Length: 36 in (914.4 mm)
  • Motor Size: Water-cooled Brushless 36x74mm 1900kv
  • Propeller Size: 1.6″ X 1.73″
  • Radio: 2-Channel 2.4GHz
  • Recommended Battery: (2) 50C+ 2-3S LiPo with EC5 Connector
  • Scale: 36-inch
  • Speed: 50+
  • Speed Control: 120A Brushless Marine
  • Steering: Offset Rudder
  • Trimscheme Colors: Black with Green
  • Weight: 5.5 lbs (2.5 kg)
Part number for the Pro Boat Sonicwake 36″ boat is: PRB08032T2 and is expected to be available in early Oct 2018 for a cost of $400.
sonicwake deep-v boat bottom
pro boat sonicwake deep-v boat rear
