HUDY power tool tips #190070
Check out the new HUDY power tool tips made from the renowned HUDY spring steel! The HUDY power tool tip ends have been manually ground for maximum precision that allow for a perfect fit. HUDY has also heat treated and hardened the power tool tips that give the HUDY power tool tips a long life. HUDY has also labeled each tip with it’s size so you know exactly what size tip you have or are reaching for.
HUDY power tool tip set includes:
#112071 Power Tool Tip Allen 2.0 x 90 mm
#112571 Power Tool Tip Allen 2.5 x 90 mm
#113071 Power Tool Tip Allen 3.0 x 90 mm
#164071 Power Tool Tip Phillips 4.0 x 90 mm
#165871 Power Tool Tip Phillips 5.8 x 90 mm
Discuss the new HUDY power tool tips in our RC Tool Talk forum.
