HPI Savage X Battery Level Indicator
HPI Racing's battery level indicator will give you instant information as to your HPI Savage X battery status. Once installed, simply turn your receiver battery on and the indicator will show you the power level of your receiver battery. The HPI Savage X battery level indicator should only be used with hump back battery packs. Adding the hump back battery pack (#2012 ) to your Savage X also increases steering performance. Foam Tape 25x60mm(#87022 ) is also recommended to support the battery.
Battery Level Indicator Includes:
  • Battery indicator
  • Battery indicator grommet
  • Cover plate
  • Binder head screw m3x10mm
  • M3 nylon lock nut
  • Instruction for battery indicator
Part #: 308 – Savage X Battery Level Indicator
MSRP: $35.00
Battery Level Indicator Installed
Join the discussion about the new HPI Savage X battery level indicator in your HPI Savage Talk forum!
