XTM Sliding clutch?????
gixxer2k1000
I decided to go with the xtm slider clutch for my savage ,the only problem I ran into was that the clutch bell is now right up against the spur gear,Its like the motor needs to to go back just a tad. Any suggestions would be very greatfull.
Thannks Tom
Is your flywheel sitting too far out? You may have a collet that needs to be milled down a bit. Snap a pic of your set up and that will clear things up.
Yea basically the flywheel is to far out.So I can take a couple of thousandths off the brass collet that the flywheel sits on? if so that is what I will do.I do have enough room between the motor and the flywheel to be able to do that.
Tom
Tom
Take some pics if possible. Take little by little off not a whole chunk. A little can go a whole lot!
Well I ground off some of the collet and it worked out for me.I also notice that my spur gear has a slight bend in it as well but everything works good .
So thanks for the info ot was greatly appreciated.
Tom
Tom
If there is a bend check your spur gear for wear on the slipper or even improper alignment or installation.
