XPS Programing for the RC18T?
FastEddy
The Slowest Guy In Town
RCTalk Vendor
El Dorado Hills, CA
I'm doing a repair job for a friend and need to program the stock ESC. I can't seem to find the programing guide on the net :(
Just the basics or a link to the manual would be great.
Thanks.
-Ed
Setup procedure for forward and reverse.
I have tried all the normal procedures from other ESCs. Either its fried or I'm doing it wrong.
DAH!
I got it.
It helps to look at the throttle trim....
All the way up.
ERRRR......
1. Turn The transmitter on.
2. Turn the ESC switch on.
3. Press and hold the ESC 'Set' button for at least 3 seconds.
The setup LED will flash red/green to confirm that the unit is in setup mode
4. Leaveing the transmitter trigger at neutral, press the setup button once. The 'Throttle Neutral' setting has been stored, and the setup LED is now green.
5. Pull the triger back to full throttle and press the setup button once. Release trigger. The 'Throttle Full is now set and the LED is now red.
6. Push trigger to full brake and press the setup button once. Now the full brake setting is set and the LED should be flashing red/green 3 time simultaneously.
That should set the ESC.
Mike H.
Thanks Mike,
I just printed this out and added it to my collection.
I appreciate the time....
I owe you one... :cheers:
