I just bought it for my son new. Followed Break in as per intructions in manual... (1) Put on block and started at factory settings, was running rich, ran for 1 tank of fuel at idle. (2) went and ran(very easy) per instructions without having to touch needles 1 of the 2 tanks it said to run on the ground in oval area, no problems. next day started on the 2nd tank on the ground and problems started. Quit running, needle adjustments made but poor performance....still running rich though.
Yesterday I set everthing back to factory settings and went from there.
Started up, adjusted idle screw adjusted Lsn so would be able to give gas without dyeing on take off. Adjusted idle screw a little more to compensate for LSN, smoke still comming out of pipe, ran a couple times down driveway and back then noticed that was running a little lean for some reason, cutoff.... zip ties on the pipe grommet got hot and melted some. Thought that was strange. End of the day for that.
Today i started it up adjusted some, still rich on the Hsn, lots of white smoke comming out but not very good power at all. Very sluggish....This would be the 4th tank that's gone thru it and I really dont know what to think. My son did make a comment that he saw bit of flame come out of the pipe once when we had started up before.
I have never had this kinda problem with a motor before.....does it take longer to break in a big block, book says 3 tanks, but I'm thinking otherwise.
Or is my engine toasted? So far engine has not been treated like a race engine, just been moderately driven around as per manual for break in.
Productive comments are very welcome! Thanks...........
