Anyone found a decent fix for this? I've recently installed an LRP28 in my savage with a 3 speed trans. I put a brand new cup on the front center when I installed the engine. I can't have more than a gallon on that engine (if I do, it's not much more) and that cup is severely worn already. The center cups on the diffs are also heavily worn. The only cups that don't appear to be worn much are the wheel axle/diff->wheel cups and the XL brake hub cup.
Is this still just a "savage" issue?
I have cups on my aftershock that have to have 5 gallons of LRP abuse and 6+ gallons of other engines abuse and they are the originals! As are the center axles! What has losi figured out that can withstand 10+ gallons of abuse that HPI hasn't? Is it just because of the extra offset having the trans up higher than the diffs that causes this? Is the only "fix" for this to get a LCG chassis?
Just checking.
Just checking.
