Work day
Yep, I did. It was in part the quick release shock pins that I made and part because of the flexing of the shock tower. Even without the quick release pins, I was getting major denting in my header.
It's your call, but I suggest having an extra tank on hand. Especially if your using the RPM tower. That's what I had and it would really bend. That's a good quality in arms, but not shock towers that ride close to things.
u really think my rear shock tower is going to hit my fuel tank? lol
did the piece of rubber fix ur glitching problems?
later
Well, I ran it. The glitch seems quite a bit better. Using the smaller tank with a 21 seems to not be the way to go. It wanted to run lean all the time. Unless I backed my needles out about 2 full turns, even still I was hitting 270 and running a constant of 250. I had very little smoke on a high speed pass. Only if I let it sit for about 20 seconds then opened it up would I get good smoke.
So, I've ripped off the tank and will attempt using a buggy tank or the stock tank. Since I don't have either on hand, I'm done for the day.
