Will this make a difference?
nitromad
Auckland
nova heads are gr8
the only problem withthem is they some times cool an engine too much which causes wear because the metal hasn't expanded enough
Nova heads are great for reducing temperatures but use caution, you can be fooled into running too lean because your temps will be lower than usual. If your engine is tuned for max power at 260 degrees, then expect about a 30-40 degree drop in temperature after putting the head on. This does not mean you can lean it out and run at 260 degrees again.
