Will hex spacers work to help not to stop the wheel from turning?
DavidB1126
Team Bomb Pop
Bomb Pop Island
Was working on the slash today and installing the 14t pinion. When I turn left or right the front tires rub on the suspension arm and causing the wheel to not move. Will hex extensions/spacers work? Here is one that I found: https://www.amazon.com/HobbyCrawler...as+2wd&qid=1639782697&s=toys-and-games&sr=1-3 These look like you need to screw in when putting on the wheel. I want to put the wheel on by a 7mm nut.
Extenders will put more stress on the arms, caster blocks, and bearing carriers. You might want a higher offset wheel.
