person123
RCTalk Racer
Okay, I have a savage x ss that had MAJOR half tank lean problems, and I got the new era OFNA tank mod which completely fixed my problem. I've run it about 4-5 times since the mod and had no problems. Yesterday, it was about 50 degrees F outside (as opposed to high 50's to mid 60's on the other runs) and the truck seemed to be running fine. I thought that I would have to tune the high and low speed needles down (rich) to compensate for the higher oxygen content in the colder air. My high speed needle was fine, but my low speed needle actually seemed rich. There was a delay in the acceleration, so I leaned it just a little bit. Then on the second tank, when I refueled, I spilled a little fuel on the outside of the tank and on the engine, but not a lot. I wiped it up, and when I brought it in after about 4 min to check the temp, there was a ton of dirt/fuel on the outside of the tank and under the rim of the lid around the seal. Again I wiped as much off as I could, and the same thing happened again, and again. I also noticed that, while there was still blue smoke and temps in the 210 to 230 F range, that the low speed and idle were ACTING lean. There was too much blue smoke to mean that they were actually lean.
sorry about the long explanation; I didn't want to leave anything out
thanks ahead of time
