why no fuel
check ur high speed needle isnt in all the way it will stop ur fuel if it is
Since I don't know what truck it is, is it a pull start or an electric start?
When you try to start it you need to plug the exhaust so direct pressure goes from there into the tank, pushing the fuel to the engine.
Is your OWB just spinning?
no its crackin:\if i put fuel directly in carb it fires, for a sec
i my self run a savage but i help my friend w/ revo out. he should be signing up soon just thought id let u know why i was saying the dirty word revo
Remove the fuel line from the carb connection. Spin the starter till fuel comes out. Put the line back on the carb and try to start it again.
sounds like the inlet on the crab is pluged with gelled fuel. when was the last time it ran ? if it sat over the winter it probly needs cleaned.maybe the outlet on the tank is pluged .have you tryed to diconect the fuel line from the carb lift the tank lide and blow in the carb end and see if it bubbels if no bubbles it's pluged .if you get bubbles then it may be the seal on the tank lide.just some ideas to try i'm not near as experenced as a lot of people on here.
pull the line off the pipe and blow into it till the full reaches the carb and try it
thanks this could b it the damn pipe is leaking!! not allowing me 2 prime engine you guys are the best friends ever.. lol
was racing like 6 times this season
hey it's always nice to talk to some one from back home ,i'm from ashtabula ohio .well i was i;m in Maryland now . man i'd like to be back home but there no work up there
whats wrong with revo's??????
