When am I supposed to measure the temps off my motor? I have a Motorsaver on my S-25 and my outside temps are hot & humid in the mid 80s. My HSN is 5 turns out, which is 1/2 a turn RICHER than the factory break-in settings. My LSN is 3.5 turns out, which is 1/2 a turn richer than the factory break-in settings. The truck runs very good without hesitation and it blows plenty of smoke. It does not have enough power to wheelie off the line with the 15/49 gearing.
After running around on and off the throttle with the body on I get temps in the mid 200s. If I run WOT back & forth across a very big parking lot a few times and then immediately take a temp reading I am somewhere in the 300-310 range. I can richen it up further, but it seems to run good as is and it blows smoke. I did try to richen the HSN even more than the 5 turns and I think it was losing performance. Should I be reading temps after running on & off the gas, or should I read it after a long extended wide open blast?
