David Gray
- Racing
I have a older full aluminum big block T Maxx with a Ofna picco 27. I removed my clutch setup do to failure and want to replace it with something durable and different looking. I saw the Fioroni Vario new gold finned flywheel setup but not sure if that is ideal for my setup. Fioroni also offers a Penta 5 that is designed for 1/8 trucks but I'm not sure if that means all aluminum heavy trucks.
I also have to address an issue of the clutch bell having a gap next to the flywheel. There are washers or spacers inbetween the engine bearing and the flywheel. Is that ok for proper balancing? If so can I keep on shimming it over to take up the gap? I'm not sure how much clutch bell movement I have. Can I use any clutch bell with the Fioroni stuff? I have a Robinson 21 tooth bell now. Does any one know where to get a good deal on a flywheel holding tool, maybe Hudy 3 way. How do I hold the Fioroni assembly for tightening and removing?
Thank you for any help...
