I thought I had broken only my motor mount last weekend but upon tear down I found the block cracked as well on my S-25. Showed it to the wife and she said "you need a new engine", so I bit the bullet and ordered a WASP.28 from tower. It should get here by next Friday. In the meantime, I'm asking all WASP .28 owners to chime in with their tips and tricks. I plan on doing at least a full 6 tank break-in at factory settings, but are there anything else I should do before that. Will it be necessary to re-seal the backplate? What turbo plugs are you using so I can get a couple spares on hand. Weather in my area has been around 40-55 degrees. Also, will it be fine running with the half gallon of Odonell 20% nitro I have left, or should I go higher in content to 25 or 30. Thanks for all your help!
