Ok Seeing how this Question gets asked aLot........
Heres Some Pics of some of the Main Difference's between the LST1/Aftershock & the LST2......
Aftershock Vs LST2,
Aftershock Vs LST2, Mach 26SS Vs Mach427 (Note; Better Linkage Set up on LST2 the LST1/Aftershock has Servo Saver )
Aftershock Vs LST2, Pipes, Sport Vs HT
LST1/Aftershock Vs LST2, Plastic Clutch Shoes Vs Alum
Aftershock Vs LST2, No Gear Cover on LST1/Aftershock Vs Inside Gear cover....
Note; Aftershock has Plastic Hub that Hold the OWB Vs LST2's Alum Hubs.....
(Same with the 2 Speed Hub, Aft has Alum Ring set in Plastic Vs LST2's is All Alum)
(Another Note; the LST1 Dose have the Same Spurs and 2-Speed as the LST2)
LST1/Aftershock Vs LST2, Tanks, 170ml Vs 220ml
LST1/Aftershock Vs LST2, Metal Pads Vs HP Pads (High Performance)
Aftershock Vs LST2, Plastic Shock Bodies Vs Alum
LST1/Aftershock Vs LST2, Wheels/Tires 14mm Claws Vs 20mm ATX's
Aftershock Vs LST2, Radio's, XR2I AM Vs XS3 FM Synthesized 6 Model Memory (Note;LST1 has the Same Radio as LST2)
Now on to 2D's Pics for the Drive train Parts........
Right is LST2,left is Aftershock
Left is LST2, right is Aftershock
LST2 CVD vs Aftershock/LST...
LST2 CVD pins are captured by this large bearing.
LST2 axles are 8mm like a 1/8 scale buggy..
LST1/Aftershock hex pin compared to LST2
LST1/Aftershock rear carrier compared to LST2
LST1/Aftershock axles compared...
Rear wheel of my LST2 after it was ran over by a 1:1 Tacoma..
Replaced Tires and wheels and completed a full race program when I got home I checked it out further (night racing or I would have noticed this)
It filed the rear carrier down on the pavement when the wheel was crush, no LST parts failed...
Hope that's Some Help to the New Guys thinking about witch Truck to go with.......
