Victory hawk thunder beast factory settings ?!
Jezza151
Does anybody know what the standard needle settings are for this buggy, can't seem to find them anywere on the net and having alot of problems tuning .
:angry:
Google shows nothing, it just brings back to thus thread.
Looks like you might be calling them.
I'm guessing this is your buggy
http://www.ujtoys.com/VHXK-Nitro-Buggy-RC-Car-p/vh-xk.htm
could you let me know what carb the engine has ( slide or rotary ) so i can find give you rhw correct tune,
off the top of my head
if its a slide carb i would try
high speed needle 3/3.5 turns from fully closed
low speed needle ether 2/2.5 turns from fully closed or flush with its housing
1mm idle gap ( adjust as necessary )
if its a rotary carb try
high speed needle 3/3.5 turns from fully closed or flush with housing
low speed needle flush with the housing or 1/1.5 turns out from flush
these are taken from my kyosho .18GXR manuel for the slide carb
and from my thunder tiger .18BXP for the rotary carb
i can't find a manuel for your buggy but if you have one even your quick start manuel should have some engine settings
once you post your carb type i should be able to give you a more accurate tune
Rotary Carburetor
Yes that's the car on the link you have posted accept my engine differs slightly like manifold and exhaust , it does have the slide type carb on it. I dropped my novarossi engine in it yesterday for sure fun and it goes like stink but I still need this engine sorted I'm going to seal it then ill Try getting it up and running with the needle setting you gave.many thanks for all the help :)
