I just got this setup board.
When mounting the gauges are you supposed to remove the wheel hexes? My guess is no.
When I put the gauges on the axles (on top of the hexes) there is some play in the gauges. I can move them around a bit left/right and up/down on the axle. This can cause inaccurate readings. How do people handle this?
[edit]
The problem is the wheel nuts that came with the kit. They are standard threaded for NTC3 axles and they do not thread all the way up my axles. I need the optional 4mm axle nuts. In the meantime I put washers in between the wheel hexes and the gauges to take up the slack.
I checked the settings I made with my dirt cheap RPM gauges and I found them to be nearly perfect.
[edit]
