MustangMan
Hey all...
I installed the uni-flow mod on my Savage the other night after installing a new backplate and the HPI engine stop. I know I have the one-way check valve installed correctly.
I put fuel in the tank and tried to prime it and it hydrolocked on me. I pulled the plug and removed the fuel and tried again, just to hydrolock it again.
Before I knew it I've got fuel soaking into the air filter from the carb and raw fuel coming out the pipe. I drained about a 20% full tank in a matter of minutes trying to start it.
I got frustrated, pulled the check valve out and the the rest of the uni-flow parts, drained the fuel, cleaned everything up, and tried to start the Savy my normal way and it lit right off. I ripped around the yard for another quarter of a tank with no problems.
So, the Savy is on the shelf with the stock fuel lines on it right now. I just can't figure out how I screwed up so bad.
I noticed I couldn't leave fuel in the tank either, as it would expand into the carb from the garage heat over time.
Maybe the uni-flow just isn't for me? Any suggestions?
Thanks...
Thanks...
