CV-
RX or CV-X?
The "X" only designates the motor being a pull start...
either way, break it in, make sure its broken in, run the hell outta it...
(Break in: 1st tank: Let it idle, nothing more, maybe a little bit of "fast idle" if it tries to die on ya, 2nd tank: Let it "fast idle" 3rd tank: vary between "fast idle" and 1/4 throttle, do this for the fourth tank too... 5th tank: "Fast idle" to 1/2 throttle.
6th tank, start messing with the High speed needle(Like 1/16th of a turn lean, no Full throttle, no more than half.
7th tank, one more 1/16th of a crank lean on the HS, might be able to start toying(1/16-1/6th of a turn on the LSN)
8th tank: Probly not broken in yet, but you can start trying to tune it.
9th: No full throttle yet... keep toying with needle settings, but make sure it's not overheating...
10th tank: Yes, I can finally floor it..
(Keep in mind, this is how i break a motor in... and most people dont do it this way...)
