Humm... Figure I'll post an update finally, been doing so pretty well at the
www.hpiforums.com.
I finally bought the alloy gearboxes. Now I have everything I need, except for some more clutchbells, rear aluminum braces, and dogbones. I am most likely going to get the dogbones machined by a shop. I cannot find any ones that re the right length. Probably drop another 200$ on just that for as many dogbones as I can. Darn money pit... Umm, bought brakes and stuff as you can see, highlighted stuff is what I bought. Again, the prices are just values, not what I paid for it. Total for the conversion to date is 3750$.
Airtronics MX3 Digital Radio - 207$
8 Hot Bodies Threaded T-Maxx shocks (Blue) - 160$
4 HPI V-Groove Tires - 57.50$
2 HPI Racer fuel tanks - 52.67$
Dynamite Fail Safe - 57.50$
2 Plastic Bumpers by Mossdog - 30$
2 OFNA linkage sets - 32.20$
2 Duratrax in-line fuel filters - 23.00$
2 Dubro in-line fuel filters - 11.50$
6' of Fuel line - 9.20$
4 Masher 2000 Tires on HPI deep offest rims - 60$
2 Kolor-Kraft Titanium rear shock towers - 90$
2 OFNA Hyper 21 8 Port engines - 621$
2 Associated 25WT shock oil bottles - 15$
Wolfpack Radicals chassis brace - 45$
Wolfpack Radicals 2-speed with first gear adapter - 110$
Wolfpack Radicals engine mounts + flywheels w/ collets - 165$
Wolfpack Radicals machined aluminum bell cranks - 44.80$
2 pairs of GPM alloy front C-Hubs - 59.57$
1 Powerline aluminum rear lower arm mount - 34.50$
1 Powerline aluminum front lower arm mount - 34.50$
2 pairs of Powerline Aluminum rear arms - 115$
2 Hitec HS-645MG Servos - 183.77$
1 Powerline Aluminum Drive Gear Mount - 57.40$
2 pairs of Powerline Aluminum Front knuckles - 91.77$
2 22T HPI clutch bells - 34.50$
24 Traxxas captured ball ends - 22$
2 Dynamite Aluminum Air filters - 91.77$
2 McCoy MC59 glowplugs - 19.55$
4 3M lock nuts - 2.86$
Hot Bodies aluminum steering link - 12.54$
2 HPI 13T HD Diff gears - 52.67$
2 HPI 38T HD diff gears - 115$
2 Duratrax Exhaust couplers (yellow) - 11.27$
1 OFNA 1:8 Dual Chamber Polished pipe (2nd on its way) - 68.89$
1 Cermark JR/ Hitec switch w/ charge jack - 14.84$
2 OFNA Clutch nuts, SG Shaft - 20.47$
2 Kyosho "Special Clutch Parts" KC45 - 68.77$
1 Kyosho Swing shaft BS45 - 18.29$
1 pack of 2 Kyosho Center shaft (Rear) IF143 - 14.84$
1 APS 1100mAh Ni-Mh Receiver Pack - 46$
1 Airtronics 110V 75mA Dual Charger - $45.90
1 set of 2 Kyosho "Joints" - the drive cups, FM185 - $21.74
1 4mm Extended/ Widened Titanium chassis - 280$
1 49T steel spur - 43.33$
1 Airbrushed HPI El Camino body - 91$
4 normal 5x8 bearings - 17.94$
2 Flanged 5x8 bearings - 11.27$
4 of those smaller bearings, lol - 17.94$
2 of those bigger bearings, lol - 13.57$
1 Starter Box - 106.95$
1 DSC 12V starter box battery - 45.99$
1 Hangar 9 12V 600mAh battery charger - 19.55$
1 Kyosho 50,000wt silicone diff oil - 16.01$
1 Set of RTR 3 diff bevel gears - 9.10$
1 Set of 4 HPI upper deck posts, called "Joint" 8.30mm - 13.69$
1 Pack of 2 Kyosho Air Cleaner Adapter - 17.13$
1 OFNA 1:8 Dual Chamber Polished pipe (The 2nd one) - 68.89$
1 pack of 6 small O-Rings - 4.49$
1 Hobbico R/C Multi Charger HCAP0100 - 80.39$
1 Hobbico Futaba Tx/Rx connectors for Multi Charger - 17.14$
1 Dynamite Dyna Glow Igniter w/ meter - 45.89$
2 Pairs - Lunsford Punisher Series Titanium Turnbuckles 2 1/2" - 34.27$
1 Pair Lunsford 2 7/8" Titanium turnbuckles - 15.99$
2 Pairs JR 41mm standoffs - 25.07$
1 Pair - JR 32mm standoffs - 17.14$
1 HPI 41T Spur Gear - 7.94$
1 HPI 43T Spur Gear - 5.64$
1 HPI 44T Spur Gear - 6.79$
2 HPI 13/20T 2 Speed Clutchbells w/ 37T spur - 45.77$
1 Pair
HPI Savage Cup Joint - 6x13x20mm - 15.99$
1 Pacer Technology Thread lock bottle - 6.79$
6' Blue Fuel Line - 10.35$
2 Dynamite .21 Exhaust rebuild kit - 11.48$
1 Pack of 10 GS Blue Aluminum Lock Nuts - 12.08$
1 Pack of 10 GS 6x11x02mm shims - 3.44$
1 Trinity Quad Wrench - 11.49$
1 OFNA Flywheel Wrench - 10.06$
1 Pack of 8 GS Blue Aluminum Linkage Stoppers - 10.93$
1 Pack of 10 GS 8-32 Blue Aluminum C-Sunk Washers - 6.89$
1 Pack of 8 GS M3x18mm Burgundy Aluminum CS Screws - 8.63$
1 Bottle of Team Trinity Final Run solution - 9.78$
1 GS Blue Roll Over Antenna - 19.54$
1 "Excellent Parts" Rod Assembly - 8.63$
1 Scalpel - 3.44$
2 Pairs of Proline 2.2" Rear Velocity Truck Wheels - 22.98$
1 Pack of 2 GS 1/8 Gray Molded Couplers - 8.04$
1 Pack of 10 HPI 2x10mm Pins, Silver - 2.01$
2 GPM Alloy Front/ Rear Gearboxes - 160.54$
1 GPM Alloy Front Mount Plate (Steering Plate) - 26.22$
1 Pack of 2 OFNA Disc Brakes - 12.54$
1 Pack Brake Calipers and Cam Shaft - 9.09$
1 Pack of 2 Thunder Tiger Center Drive Joints - 19.44$
1 Pack of 10 Kyosho Silicone O-Rings, 4.5mm - 6.79$
1 Pack of 4 GPM Alloy Clamp Type Wheel Hexes - 22.77$
2 Packs of 2 HPI Front Axles - 20.47$
1 Pack of 2 GPM Alloy Steering Tie Rods - 13.57$
2 Packs of 2 HPI Diff Shaft (Silver) - 22.77$
1 Pack of 12 RPM Long Shank Rod Ends (4-40) - 9.09$
1 Kimbrough Servo Saver - 11.27$
Total: 4674.98$
Another update. The truck is ALMOST ready to run. I basically assembled everything that needs assembling, now I am just waiting for my dad to come from work with the dremel so I can dremel at the chassis, so that the alloy gearboxes will fit. The hole in the chassis does not match the part that sticks out on the bottom of the gearboxes. Must make hole bigger.
Also, the brakes I bought are a tad too large in diameter. When I put them on, the screws that hold the brake pads on rub against the rotors. So, my dad took them to work as well to take off about 2mm around. No biggie. I can't find 2 of my brake pads though So I only have 2 for now to work with. Oh, the rotors/ discs are fiber, not metal. I will be running most likely one in the front, and one in the rear.
Assembled the diffs as well. Packed them with 50,000W Silicone oil, that was fun to watch the oil contour to all the little grooves in the diff cases. That went without a hinch. Also, bought these silver HPI outdrives, which are supposedly the Rush outdrives, or at least stronger than stock. Using those right now. Also the RTR 3 spider gears. 13T and 38T finals too. Now all I need really is those dogbones. Man, I am gonna kill myself when I see how much they are gonna run me. Ah well, I'm the one that dropped $4,800CAD into the NMT in the first place
The steering is all assembled, got the Kimbrough servo saver, that works like a charm. Everything is super smooth except for the ball ends. But hey, I don't want them smooth, they will break themselves in, no need for a drill or anything to make them fit better in the cups.
I'm running the shocks in the outer most hole in the Kolor-raft shock towers, and the inner most hole on the A-Arms, front and rear, well, rear and rear lol. Also, the shock towers required a little bit of persuasion to fit over the alloy gearboxes,as aluminum doesn't tend to bend as much as plastic can. After about 30 mins of filing at the 3.2mm Titanium, they fit. The 2nd tower only took about 10 minutes of filing. Yay. In both towers, 3 screws went in fine, and one had to be "persuaded" to go in. As a matter of fact, I couldn't even fit one through, so, I put in the opposite way, and secured it with a 3mm lock nut. I like symmetry, so I did the same to the other screw on the opposite side. You will see in the pictures which will come soon enough
What else? Umm, yeah, all that is keeping the truck from running right now is really the dogbones. Everything else is figured out. I just have to buy the bigger CBs, and the alloy rear braces. That is it. We are almost there The truck really looks amazing right now.
Oh, I guess I should say I have body posts as well. Borrowed them from work. Found these cool looking things that can be used as long body posts, so took like 10 of them. Paradox took like 8. lol. Have to find a place to mount those. And, just one more hole in the chassis to drill for the antenna. Heh, the truck really looks amazing. I cannot tell you how amazing it looks. It's unbelieveable. Oh. Also, I was just thinking, and I may after all do the 4 wheel steering. I can see how I can fit bell cranks in the rear, but that is for a later date.
And the buggy wing will be put on a little later, but it will be there, don't worry.
