OK, put my maxx back to factory settings as best I could (HSN 4 turns out, LSN at a point where pinching the line gives me 2 seconds before it cuts off).
Took it for a couple high speed runs, then measure the temp.......300!!!??? I leaned the HSN out a little, and then the temp dropped down to a max of 270 after a couple more runs.
My issue is that with the engine so rich, I can feel the lack of top-end power. There is blue smoke coming out the whole time during the run, so I know its already too rich. You can even smell the nitro. It also shifts very late into second (later than during break-in).
Its about the same outside temp as break-in was, but its definitely more humid. After I richened it up, I was at 4.25 turns out on the HSN, which doesn't sound like much more than stock, but will that be the minimum I can leave it at? If so, my high speed is definitely suffering.
The truck is only a week old..........could I have toasted the motor already? Thatd be a major bummer (its only on its 8th tank). If it stalls, its never hard to restart, and it didnt cut out under high speed acceleration like overheated engines seem to do. Thats pretty much why I didnt know the temps were this high (I dont know how long its been this high, I just got my temp guage).
Any ideas? Any easy way to tell if I roasted the engine already? (aside from tearing it down). Is it possible I'm taking the temp incorrectly? (I have the Radio Shack infrared temp guage, and to get a reading I was putting it directly above the glow plug and resting the case against the black plastic ring around the top of the cylinder head..........perhaps I was getting a false high reading?)
Thanks!!!
-Chris
Thanks!!!
-Chris
