trying to adjust servo/throttle linkage
hornet7288
I am working on getting my old Duratrax Maximum ST up and running again. I have the motor unseized, have replaced some things here and there and while I am waiting on some fuel to come in the mail I figured I would adjust the throttle linkage.
I am assuming it should be adjusted so that at the neutral position the engine should idle, wide open the carb is fully open and full brake the brake should be engaged and the engine should be idling.
Problem is that it doesn't seem the throttle/brake servo is giving me the full range of motion. That or I am just a noob and I am not adjusting properly.
When I set the linkage up so that the engine idles at the neutra position I'll get half throttle at best (based off of looking at the carb) when I give it a wide open throttle input from the controller.
Any pointers?
I will add that because I wasn't sure any of the electronics still worked I bought cheap (dollar store) panasonic AA batteries. Could this possibly be a contributing factor?
After searching around online and youube I think my problem is that my LSN is set way too low. I'll dig into it tonight to double check. Unfortunately I work until 23:00 hours so I won't be off for awhile =/. I hate coming to work in the middle of an unfinished project.
Set your idle with the idle screw not the linkage. You want a 1mm gap in the carb slider. Once this is done install your linkage and adjust. If you can't get WOT after adjusting linkage check the end point servo settings in your radio and make sure its set to give you WOT.
29
easy rider
normrdz300
8
normrdz300
normrdz300
SiN360
4
Weezel
Weezel
normrdz300
4
3K
normrdz300
normrdz300
