i have a question about the traxxas waterproof 2056 servo(stock revo5309 throttle servo) is it a decent servo?. it sells $13 on ebay just wondering if its worth buying
i use the 2075 for throttle /break ...works great and it is a bit faster than the original 2056.... just one 2075 for the steering will work good to ...so you can always take one of your steering servos if you have problems
all you have to do is take one servo off ....and if you want , you can cut the arm off the bellcrank on that side ..but its not necessary ..i left mine on ( on both my revo's) ..just in case the other side ever breaks of or if i ever want to put dual servos again
some will say that you should put a stronger servo if you go to a single servo setup ...again , its a matter of choice ...i find that just one original 2075 works just fine
I run a 2070(just not water proof) as throttle and a single 2075 for steering. I had dual steering, a 2070 and a 2075, and a 2070 for throttle. The throttle broke, so I just moved the 2070 steering to throttle and I'll replace it with a 2075
