transmission care
chewyboy
RCTalk Qualifier
ok, i dont have a manual and i didn't see this on traxxas site anywhere. what is the correct lube (if any) to use in your t-maxx's transmission?
thanks much
the stock trans has plastic gears and requires no lubrication. nylon is pretty much self lubricating. if you start replacing gears with steel or aluminum then it will require that use use a light lubricant.
