Paul
RCTalk Qualifier
So after some street laps yesterday I inspected everything as I always do after running my kit and noticed that the front bearing in my engine seems to be leaking. Not bad but I'd assume any leak here isn't a good thing. Bummer. Took the engine and carb completely apart and cleaned everything. Piston and Sleeve are still in really good shape. No metal shavings anywhere. Hoping that a piece of dirt got between the crank shaft and bearing and a good cleaning is all that was needed. Rather not have to replace the front bearing cause I don't have the tool for it but if it continues to leak then I'm gonna have to. Any peeps have their own DIY method for removing of the bearings? The bearing puller/press tools are WAY over priced. Thinking a wooden dowel that's the right size and some tapping with a hammer would do the trick. At least the bearings are inexpensive to replace.
