tmaxx tranny issues?
beshears8807
Bashing
when i was driving my tmaxx yesterday it was running top notch and all of a sudden it dies i started it back up but know just revs up and doesn't go no where if you pick it up off the groung it will go but seems very very weak like a clutch slipping. I'm new to gas rc cars so would very much appreciate the help. note: earlier in the day broka a drive shaft knuckle but was replaced and worked fine. please help!!!!
Suicide
Gone - bye bye.
Bashing
does it make grinding noises. and also email traxxas support they are excelent
LosiLST
Gone - bye bye.
Washington.
Bashing
Sounds like your spur gear and slipper clutch. (big gear that sticks out of tranny) tighten that and you should be good.
beshears8807
Bashing
tranny apart
pulled tranny apart and this little pin about 1/4 of and inch long was laying in the bottom? what could this go to?
LosiLST
Gone - bye bye.
Washington.
Bashing
You still have reverse right?
I beleive that goes between the forward and reverse primary gears on the main shaft.
LosiLST
Gone - bye bye.
Washington.
Bashing
Okay, well there is a pin, it holds the gears in place on your main shaft? I think thats where it goes.
Take a picture
beshears8807
Bashing
tranny issues
would this cause it to not work right?
should 4985 spin freely while holding 4984 still?
LosiLST
Gone - bye bye.
Washington.
Bashing
Yes, because the gears would be sliding forward and not gripping properly I Think.
I havn't owned a Tmaxx in about a year so I am going all off memory.
gregM784
RCNT Rookie
Sacramento
Racing
I broke a 4995 today in my maxx. It made all sorts of noise, but still 'tried' to move. I'm learning the trans, so bear with me. 4995 has a screw pin on it, that holds it to the shaft. Try it.
FrankieSquid
RCNT Basher
Arizona
Bashing, Racing
Hey that's exactly what happen to me. Might sound weird but try adjusting the Highspeed needle. I would crack open my tranny if all else fails.
beshears8807
Bashing
tmaxx tranny issues
TMAXX TRANNY PROBLEM FIXED i guess when i broke the drive shaft knuckle i must have sheared the pin that is in tranny that goes through a gear and main shaft. CHEap fix. thanks
Chazz
RCNT Rookie
TomsRiver NJ
Bashing
Is there anybody know if the New TRAXXAS T-MAXX 3.3 4908 EDITION (2 Speed Forward ONLY Racing REVO Spec Transmission)work in old t-maxx 2.5
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
Pattertickle 2.5 Tmaxx tranny issues Nitro RC 11
DylanWillette TMaxx 2.5 tranny in a 3.3 chassis Chassis & Drivetrain 1
Midnyteryder196 Tmaxx 2.5 motor with 3.3 tranny Traxxas T-Maxx 5
T tmaxx tranny question Traxxas T-Maxx 12
buggybuster TMaxx 3.3 tranny Traxxas T-Maxx 2
J New TMaxx Tranny Traxxas T-Maxx 7
D Help w/ 1st generation TMaxx tranny Traxxas T-Maxx 5
F Tmaxx tranny single to two speed Traxxas T-Maxx 5
I tranny problems with tmaxx .15 classic Traxxas T-Maxx 3
E 3.3 Tranny in a 2.5 tmaxx Traxxas T-Maxx 1
J tmaxx tranny NO GO Traxxas T-Maxx 18
H Tmaxx 2.5 with big block twisting tranny output shafts!!! Please help Traxxas T-Maxx 7
H tmaxx tranny upgrade? Traxxas T-Maxx 2
D Revo or Tmaxx tranny in TNX Nitro RC 0
A Revo Tranny In Tmaxx? Traxxas Revo 1
B Tmaxx tranny woes? Traxxas T-Maxx 4
S savage tranny in tmaxx Traxxas T-Maxx 0
C will a 3.3 tmaxx tranny work in a 2.5??? Traxxas T-Maxx 4
D tmaxx tranny Traxxas T-Maxx 4
N tmaxx tranny Traxxas T-Maxx 2
F Tmaxx tranny Traxxas T-Maxx 18
Z Tmaxx tranny question. Traxxas T-Maxx 7
O rebuilding a tmaxx tranny. Traxxas T-Maxx 3
jlobbia Tmaxx big block problems Nitro RC 8
jlobbia Tmaxx engine is fine but barely moves Nitro RC 27
Nrboxer Tmaxx part repair ? Nitro RC 9
D Tmaxx 2.5 Nitro RC 5
R Tmaxx clutch Traxxas T-Maxx 5
Brody hawk My tmaxx is having 2nd gear issues Nitro RC 4
D .15 tmaxx engine fot on an redcat amd??? Nitro RC 6
J Traxxas Tmaxx Burning through glowplugs Nitro RC 9
J Traxxas Tmaxx 3.3 won’t Run Nitro RC 3
Brody hawk I need help with my tmaxx 3.3 Nitro RC 9
gmparts57 Used 2.5 tmaxx help! Reverse disabled? Traxxas T-Maxx 3
D Tmaxx making loud grinding sound Nitro RC 2
D Tmaxx with OS .18 cvR Nitro RC 10
D My tmaxx with the O.S. .18 max CV-R. Monster Trucks 3
K What servo to get for old tmaxx Monster Trucks 5
M What Tmaxx do I have and what should i swap If anything. Traxxas T-Maxx 5
TxGuy Tmaxx 2.5 to 3.3 Conversion Nitro RC 1
tablelegslim86 picco .26 tmaxx 4909 build RC Builds and Projects 6
corycoleman Tmaxx 3.3 tune Traxxas T-Maxx 2
rudedog03 Help with tmaxx 3.3 Traxxas T-Maxx 1
C Tmaxx 4 wheel steering Chassis & Drivetrain 1
prauner TMaxx throttle Traxxas T-Maxx 5
DXtreme1 DXtreme1 TMaxx Dual Builds RC Builds and Projects 82
Greasemonkey91 Tmaxx transmission question Traxxas T-Maxx 3
N Tmaxx 3.3 keeps stalling Nitro RC 9
G Tmaxx Orig vs 2.5 engine shaft and clutch ? Engines 1
M Tmaxx 2.5 breaking issue Nitro RC 6
