Tmaxx 3.3 Not Starting
lakevilled
Ok i have a Tmaxx 3.3 that i just got but i got it used. I started it up and than it ran fine but right away it started to spray either fuel or oil from where the glow plug is so i took the glow plug out and took off the head to see if there was a gasket or something not sealed. but that was not an apparent problem, that i saw. Than i put it back together. And it started right up but quit right away. And now it wont start and one thing i noticed was that the fuel line from the tank to the carb did not appear to be filled. Please give me any suggestions as how to fix the problem. thanks
glow plug.. does it have good compression....... can you turn the flywheel with your finger real easy...... start with factory settings that will give u a starting point... oh replace your fuel line too..last but not least make sure your glow plug is igniting
I'm having the same problem on my 2.5 - I crank and crank the motor, but the fuel line never seems to get filled with anything ... I have checked, and both the pressure and tank-to-carb line are clear (I can blow through them, but they do not appear to leak)... any suggestions?
:) Thanks!
