First of all, welcome to RCNT!
Now down to business...
It sounds to me as if your issue is likely a pretty easy, quick fix. The 'engine clutch' is exactly where I would start looking. Make sure you haven't just worn them out. Although a single gallon of fuel does seem to be awful fast to blow thru clutch shoes, depending on how they were set, if there were any contaminants that got into the bell, even rust on the bell could drastically reduce the lifespan of them. Also, make sure everything is set correctly. The bearings should be right and spin free and smooth. Be sure that your springs are in good shape as well.
There are other things to consider here also. Be sure your brakes aren't hanging up or dragging at all. You do need to be sure that your slipper is set correctly. Have you changed any of the gearing, running stock sized tires, any other modifications?
How are you using the truck? Are you racing it? What do you surfaces do you run on primarily? There are a number of aftermarket clutchbells and set ups that are designed to disipate heat and handle the abuse of higher stress on the driveline.
Yes, a simple fix is likely but many things to consider before you get to the actual fix.
Look for the actual problem and let us know. Also, let us know about all the other info. There are a LOT of tmaxx owners here who can get you set up right.
Good luck!!!
