- Aurora, Ohio (Cleveland)
- Racing
Ok gentlemen, I've had my twin engine fun. But now it's time to go racin. I want to pull one engine out of my Maxx and turn it back into it's stock formation. For this I will need a basic .21 extended chassis plate. Here's the problem I have though....
When I orginally bought the twin chassis conversion the engines would not fit properly. I could not slide the engine close enough to the spur because the rear bumpout for the primary shaft on the tranny case got in the way of the screw on the end of the engine's shaft. I simply had a friend of mine make me a new plate with the engine mount holes moved 1/8" rearward. So if my engine wouldn't fit on that chassis it makes sense that it won't fit on a standard .21 chassis either. I don't understand what the issue is in the first place. Here's a short list...
OFNA/Picco .26 w/18T CB (will need smaller bell when downgrading)
RC Solutions 52T big block spur
New Era twin engine chassis (basically the same engine layout as normal .21 chassis)
New Era .21 motor mount
The New Era parts are supposed to be designed for .21-.28 engines. The problem will only be worse when I go to a smaller CB because the engine will have to be even closer to the tranny. What gives? I thought maybe I got a bad chassis plate to begin with but I checked the original (twin, unused) against a stocker and the engine mount holes are in the same exact place in respect to the tranny location. What can I do to make this stuff work?
