THS header help
liftedcj7on44s
RCTalk Champion
Fayetteville, N.C.
Ok i picked up a new THS header for my revo tonight. I've got a question. It comes with 1 long spring. Is this spring supposed to wrap around the whole base of the engine??? If so how the F do you get it all the way around?
NVM this thing is junk. I tried stretching the spring to fit around the engine and got it around but then it was too loose, Then i could not get the resonator part of the pipe to fit right and there was no way i could get the hold down bar bent the way it needed to be bent to hold the resonator on. This was a waste of my money as the spring is ruined and it does not fit worth a crap.
how do i remove the pivot balls from the axle carrier. i am sure that the new axle carrier is not going to come with the pivot balls. I just hope my local LHS has the axle carrier and LF halfshaft in stock, if not I'm gonna go crazy this weekend.
figured it out. a 5mm allen wrench works wonders.
Calm down man. That's a good pipe. I had a 3.3 THS pipe on my old 3.3 and it was great. You can get replacement springs if you need one. The best way I've figured out how to stretch a header spring around an engine is to use another spring to hook to it and yank it around and into position.
I can't help much with your other Revo questions as I've never owned one.
