PaulC
RCTalk Champion
I'm debating if I should keep throwing money into the Vapor, upgrading more of the eggshell plastic parts with alloy parts and learning to drive better
The problem with the alloy upgrades is it moves the damage onto the diff cases and suspension holding brackets etc.
The plastic parts are cheap, but one particular part, the front C hub carriers are so weak they break hitting stones the size of golf balls. They super glue well, thankfully, at £6 a set and you break at least 1 every run of the buggy, is it worth it!?
I have conflicting information, some say it's based on a Hyper, some say it's based on a Losi 8ight. Without seeing the dimensions on parts I can't tell if the Losi or HoaBoa /Hong nor parts will fit. I'd certainly consider them, even if I had to upgrade a bunch at a time.
The other option is to pull the engine out of it and buy a race roller of something fairly decent. Don't think I could stretch to a Losi 8ight for example, think they go for around £400 if you are lucky.
Any opinions?
Paul
Any opinions?
Paul
