AC48
Hey all,
I need some serious help with my throttle linkage. SOme of you may know that when I had the 3.3 engine and stock servos it wasn't opening my carb all the way, but just about. Now I have an RB TM523 mounted in my Revo, along with a Hitec HS-5625MG servo. Now my problem is much worse.
With the engine out of the truck, the carb opens smoothly. The throttle linkage also works very smoothly when not attatched to the carb. As soon as I mount the engine up and slide the linkage on, it comepletely jams at half throttle. From idle to half throttle everything is perfectly smooth and quick, then it just jams. I am completely stumped. This makes no sense to me.
I broken in my engine with it like this cause I didn't need WOT anyway. Even with the carb only opening half way it has just as much power as the 3.3 did. Just doesn't have the top end obviously. It even wheelies, which as me worried, it must be insane once I get WOT haha.
Anyway I think I need to completely redo my linkage. I have always hated linkages...so a step by step would be good haha.
Thanks.
Thanks.
