Throttle gets stuck fully open
pjoseph
RCTalk Qualifier
studio city CA
Is there a way to adjust the arm on the carb? The attatched to the bottom of the carb held on by a nut but i could not romove it It seems like the new engines carb is slightly off from where my old one was stock monster nitro king
So at full throttle the linkage and the arm on the carb almost form a straight line so it gets stuck.
Thanks
I believe it more the angle the carb is at, like at open throttle the arm on the carb is at 90 degrees which makes it get stuck
Then you should be able to loosen the set screw on the barrel arm(the part the linkage attaches to) and adjust accordingly. If you don't have this option, then you'll have to adjust the whole carb. Be sure to re-seal and let it dry before running.
My Truck has a spring which springs it back after throttle and either I've 4gotten to put it on or it has slipped off in a crash causing my throttle to get stuck at full throttle...
not sure if yours even has a spring..?? just my expereince anyway..
Goodluck:)
