need more info...
No problemo
Hammer Transfer Case
Ratio - 1:1 Gearing 32P hardened steel gears, 8 bearing Design, cast casing
All New R3 Scale 2 Speed Transmission
Ratios: Pinion/spur 14/64 =4.57:1 Internal 1.78:1 Gears - Wide steel 32P, Delrin spur, slipper clutch
All New Cast Yota II Axles
Ratio: 15/40 = 2.67:1 Width at hex 180.5mm
Beast II Suspension
Double triangulated 8 Link rear suspension.
3 Link front suspension with panhard bar
Shock Absorbers
Dual Spring 80mm Shocks - Can be oil filled
Wheels
Type: 1.9 Scale Beadlock Wheel
Hub: 12mm Hex Width: 25mm
Back spacing: 16mm
Bumpers
Machined billet aluminum, lightweight
Beast II Dimensions
Wheels base F-R: 408mm(16.1”)
Wheels base F-M: 292mm (11.496”)
Width: 211mm (8.3”)
Height: 226mm (8.9”)
Ground clearance: 60mm (2.4”)
Final Drive Ratio: 1st - 62.1:1, 2st - 22.75:1
How bout a few more pics as well...I am loving this camo paint scheme!
