Originally posted by RaCinJason399
The car is soo light... Hey i dont Give a poop! if u think u know.. then think that but ur wrong. Ur not the one with the car... u dont know how light it is and with just little change to it makes it fly.
Plus I DIDNT say 70mph Mayhem i SAID 60's wow u can read ... i guess hooked on phonics work for you
My gearing is 15/21T and the spurs are 120T/108T
Where u go X? Find out YOu were WroNG?
Its been a while... huh no X still
Actually I had you ignored so I didn't have to bother with you but since you demand I tell you whats up here goes...
look
here for two speed kit that shows actually gearign I called duratrash today talked to SCOTT in tech support he told he this was the only two speed option for maximum lines, He also said the standard truck has a 10.8 to 1 final drive ratio and that the stock bell is 15t and the spur is 52 t with that data you can deduct the gear box ratio is 3.12
Now with that data lets look at how fast your truck goes with the best gear ratio for speed aka second gear you said your gears are My gearing is 15/21T and the spurs are 120T/108T
Ok so lets see how fast you go with the .15 OS MAX used in all examples
Gear Box Ratio = 3.12
Spur Gear Teeth = 120 for high gear
CB teet = 19T for high gear
Tire Diameter = 3.75 in
Maximunm RPMS = 29000
Spur/Pinion Ratio 5.714
Gear Ratio 17.829
Rollout 0.661in
Top speed estimate 18.147 MPH
Yup thats right that baby will go a smoking 18.147 with your BOGUS gearing ratios you gave us. Nice try. Here is what you will get if you run the real gears which is decent for duratrash but not for the money you spend to make it go that when a TL or AE RTR does that strait out of the box with a one speed and TRX BRICK will pass it at half throttle
Here is the legit specs of your truck
Spur Gear Teeth = 48 for high gear
Spur/Pinion Ratio 2.526
Gear Ratio 7.882
Rollout 1.495
Top speed estimate 41.046MPH that is respectable at least but it dosen't matter how light it is with that gearing and those rpms it can't brreak the laws of mathmatics and physics Hope that helps with that answer you will go back to the igonore list have a good day kid and do some research before you start tring to bull crap people....X
