The Question Game
No question hpi guy you dropped the ball...;)
How much wood can a woodchuck chuck?....if a woodchuck could chuck wood.
not sure, but I'm glad they didnt.
Ever notice that the initials for lane bryant are lb? ....as in.... pound
Love copy n paste, some hubub...
The phenomenon that hot water may freeze faster than cold is often called the Mpemba effect. Because, no doubt, most readers are extremely skeptical at this point, we should begin by stating precisely what we mean by the Mpemba effect. We start with two containers of water, which are identical in shape, and which hold identical amounts of water. The only difference between the two is that the water in one is at a higher (uniform) temperature than the water in the other. Now we cool both containers, using the exact same cooling process for each container. Under some conditions the initially warmer water will freeze first. If this occurs, we have seen the Mpemba effect. Of course, the initially warmer water will not freeze before the initially cooler water for all initial conditions. If the hot water starts at 99.9°C, and the cold water at 0.01°C, then clearly under those circumstances, the initially cooler water will freeze first. However, under some conditions the initially warmer water will freeze first: if that happens, you have seen the Mpemba effect. But you will not see the Mpemba effect for just any initial temperatures, container shapes, or cooling conditions.
Why dont women take this hobby seriously? (RC)
Because they understand the amount of control we have . Were as normally they control us they don't like it that we can be in charge of something .
What is the 3rd series called in the latest transformer film ?
Transformers: Dark of The Moon (Looks f'n badass!)
Why does some stool float, and some sink?
because some stools are more rich in left over food and undigested bits therefore creating a heavyier mass compared to a light and fully digested stool ,
who was the 6th post in this thread ?
Because you lack common sense :)
What car did bumblebee 1st transform into on the 1st transformers movie ?
ME!
Did anyone actually read HPI's answer to why hot water freezes faster than cold water?
yes. and it doesn't answer the question. It just says that normally cold water will freeze first but sometimes warmer water will freeze before colder water. Doesn't give any insight as to why it happens, just that it sometimes does.
What is the most played song on the listening device you choose to listen to?
I know ill get a lot of s**t for this but I'm a kid and the most played song on my itunes is Roll Up by Wiz Khalifa..
What was your first car? And how much was it if you still remember?
